seeing the alpha tag
SVFC462
Connecticut
#1
this might a completely stupid question and i might be over looking this or missed a previous thread but here it goes ....
How do you get a feed that says"alpha tags available in this broadcast" to appear in any or all of the player type selection?? Am can see the alpha tags on the app i use on my phone but when i try to see them on a feed when listening on a computer ... they don't show up. Is there a specific player type i should use to be able to see the alpha tags?
thanks in advance.
-BOUD
W8RMH
Grove City, Ohio (A Bearcat not a Buckeye)
#3
ScannerLive also displays the IDs.
ScannerLive takes online scanner radio feeds and turns your computer into a scanner of your own.
- Select multiple online feeds to monitor (up to 10) per window
- Save your layout in up to ten banks
- Scan all feeds, and if audio is heard on one it will mute the others
- Selectable Delay & Priority settings
- Ability to change the volume settings individually
- Audio meter active on all feeds (even when they are muted!)
- Temporarily lock out a feed
- Manually hold a feed until pressing scan again
