The RG-8x isn't really that much better than RG-58.
Feed line losses vary depending on frequency and cable length. Higher Frequency = More loss. Lower frequency = less loss.
also,
Longer cable = more loss Less cable = less loss.
20 feet isn't really enough to make much of a noticeable difference, unless you were switching from some cheap Chinese crap cable to the above mentioned combo mounting mast/feed line 7/8 heliax.
RG-58 would be just fine if that's what you have available.
If you need to buy a new cable, Times Microwave LMR-240 is some nice stuff. Still small enough to route through walls easily, still fairly flexible, but a bit lower loss than the others.
The drawback with heavier cable is that connecting it directly to your radio is going to put a lot of strain on the antenna connector. You really do want something fairly flexible and light to do that. For a 20 foot run, no point in doing transitions from one to the other.
The Antenna Farm will do custom cable assemblies for you.
https://www.theantennafarm.com/catalog/coaxial-cable-342/custom-made-cable-assemblies-344/
