Seeking MT1000 VHF Low-Band 99 Channel Codeplug for 6 Meters.
Mindset539
Las Vegas
All,
I seek your assistance with locating a robust 99 channel codeplug for a low band MT1000.
I am specifically seeking one that has 6 Meter amateur repeaters.
If it also has low band frequencies to listen to that are not ham, that's fine.
Best regards to all,
Kevin Williams
NI8H (I'm good in QRZ)
petnrdx
Hudson, FL
You should be able to program 6M channels in, but the VCO's OFTEN won't go very high in the band.
I will look in QRZ.
petnrdx
Hudson, FL
Forgot to mention, there wasn't an actual 99 ch low band MT1000.
The "display" model was only supposed to be 32 ch.
That said, I have seen some that were 99 ch as they had controller boards that must have come from V or U radios from the
factory.
The most common ones I have seen were only 32 channel.
H41GCJ130AN
If you have a 32 ch controller you can't dump a 99 ch codeplug in.
ve3ext
Just acquired a working mt1000 on 49 mhz.
Will it tune as high as 53.000 receive and 52.525 w/out major surgery??
I have read the info on repeater builder site but am unclear ithe above freqs.will work?
If possible can someone assist with programming?
Happy to compensate for services.
tnx/73
Jerry VE3EXT
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Not sure how I missed this the first time around. There definitely was a 99 channel low band MT1000. The Ministry of Natural Resources in Ontario bought them brand new from Motorola in the early 90's. My girlfriend was issued one and she brought it home to show me and at that point, I knew she was a keeper.
Model number on mine is H41GCJ7130AN. Never tried 6m on mine but from what I understand, you just hex edit the codeplug and hope the VCO locks. If it doesn't, you can ground the VCO Lock Detect line according to HT600/MT1000 (batlabs.com)
petnrdx
Hudson, FL
Most will work fine up to 52.525, but might not go much further.
Maybe one out of ten will go up to 53.00.
Grounding the lock line only gets you a little. its not like it makes the VCO NEVER go out of lock.
If the VCO just STOPS, then having the lock line grounded won't help.
