XPR Selectable Encryption/Privacy Keys on XPR7550e
dmason04
I support our police.
BEE00-152-1-5
Howdy,
I've set up a new XPR7550e and programed the Enhanced Privacy keys onto the radio. When I program a channel, I can only select one key. Is there a way to select a different key on the radio through the menu like the APX or ASTRO series or is this not a thing with MotoTRBO?
tweiss3
Is it time for Coffee?
Ohio
Are you talking on the radio or in CPS?
I just opened CPS16 and added 3 keys. Under a digital channel, you check Privacy and below is the dropdown of keys.
dmason04
BEE00-152-1-5
On the radio, I know about the dropdown but I was curious to see if the are selectable in the radio's menu like the APX series.
tweiss3
Ohio
I've never done it on the radio.
Have you enabled "Dealer" for the Front Panel Password?
dmason04
BEE00-152-1-5
I do have it enabled but it doesn't show an option for key selection on the menu. I would assume this means it's not a thing on TRBO.
tweiss3
Ohio
After doing some reading, it appears that Keys are not accessible at the radio level, can only be changed with CPS/RM or OTAP, and the radio user can only on/off privacy, not change between keys.
EWC_BDN
That sounds like something Motorola would make an APX only feature. Might have to just add the same channel with different keys if you want to switch.
