You have a link to the feed?Everything appears correct from my end. The computer is receiving audio signal at a proper level, the software says "running", etc. but when I try to monitor the feed from my telephone app, all it says is "currently offline". I have been trying everything I can think of to ensure that everything is configured correctly, yet Broadcastify still doesn't seem to receive the signal. I am about to give up.
https://www.broadcastify.com/listen/feed/29964You have a link to the feed?
I have not a clue what the problem is. I don't use Scannercast so I can't help you with any trouble shooting.
It will show the tags on the 125at also just select 325p2 in the drop down box under the Metadata tab. That is what I am using for my feed.I gave up completely on Scannercast. I have installed the ProScan version, hopefully that will work. Fingers are crossed....
You feed is up and running i am on it as we speak.
You need the USB cable for the tags. And the existing audio cable you use now.Yep, it's working! I switched out scanners, though. I replaced the BC125AT with an old Uniden 860XLT.
What connection is necessary for the BC125AT to communicate with the computer / software? A USB cable? That will also pass the audio?
