Sentinel BCDx36HP Datebase Reconstruction
KR3LC
Pasadena, Maryland
#1
I've searched the forums and I have read a lot of information and nothing has helped me to zero in on my particular issue.
I was creating a new FL and all was going well but then I had to restart the PC. My database resides on a drive that needs to be reconnected at boot up.This has happened before and reconstructing has always worked. Until this time.
I was able to reread the scanner and get everything back except for the FL that I was creating in Sentinel. I can see a hpd file that was created for my FL. I can read the contents with a text reader.
Is there any way to get this HPD file to be read by Sentinel now?
Thanks,
Rick
ofd8001
Louisville, KY
#2
One way comes to mind that you can try (may be some others).
In Sentinel, go to Tools>Options. In the Sentinel Folder box, change that to point to the path where you discovered that HPD file. Click OK.
Hopefully you will see that lone FL. Then go to File>Export to HPE file. Go through the steps to make an HPE file from that Favorites List. Note the location of that created HPE file.
Then using Tools>Options, change the Sentinel Folder back to where all your other Favorites Lists are located.
Lastly go to Files>Import from HPE file. Locate that created HPE file and import it.
Hopefully this accomplishes what you wish.
KR3LC
Pasadena, Maryland
#3
ofd8001 thank you for your suggestion. I actually just recovered the file and came back here to find your suggestion. What I ended up doing was creating a new folder for all data to be written to by Sentinel. I reread my scanner. Saved as a new profile. Then I added the hpd file in question from the previous location into the new favorites list folder. I then reconstructed the database and there it was again. Whew!
