Sentinel-SDS100 Programming
PRO2006
This might need to go to the Scanner Software page, but I will throw it out here.
First time programming SDS100- Want to monitor CSP in Woodland Park. In Sentinel I go through the database, pick Teller/Statewide/State of Colorado DTRS/Colorado State Patrol.
Next I select the desired talk groups and Append them to a new Favorites List (FL).
The talk groups show up just fine in my new FL, but every single tower in the whole state also shows up! I only want the Woodland Park tower, so I have to manually delete every other tower in the state. And this is a delete/confirm for each tower. Cannot delete multiple towers at the same time in the FL.
If I did load the scanner with that it would one by one scan every tower in the state looking for four TGs.
I must be missing something..
Frankhappyg
Northeast,Ohio
Edit your favorite list
Highlight The state of Colorado DTRS.
Top tabs click sites
Drag to highlight all ones you don’t want and hit the red X
UPMan
In Memoriam
Arlington, TX
Or, set your location. The scanner will automatically avoid all the sites that are outside your location/range (assuming you've enabled location control for the FL).
