Serial cable interface for Base radio to GPS computer
Motoflightmedic
ÆSØ
U.S.A.
Would anybody have any idea where to find ready made cables or pinouts, schematics for rolling my own?
kd4efm
EL98 Florida
Do you have the gps model in the radio or you using it to decode? If decode, set com 1 to gps data and use a regular db25 to 9 rs232.
Sent from my SM-G935P using Tapatalk
Motoflightmedic
ÆSØ
U.S.A.
It will be used to decode the data and send it out to the server.
Sent from my SM-N910V using Tapatalk
kd4efm
EL98 Florida
Then a regular 232 to 9 pin cable will work. Nothing special. Just change com1 to gps/data
Motoflightmedic
ÆSØ
U.S.A.
Do you happen to know what I would need to get to connect to a nx-720?
kd4efm
EL98 Florida
That's a db15 plug, you will need a special cable for that. There is not part number listed for that.
Motoflightmedic
ÆSØ
U.S.A.
I did some research, will I still need to do the chip resistor changes with this special cable you speak of?
kd4efm
EL98 Florida
Have not seen that information, I use the nx700/800 for gps stuff, easier to deal with.
KCT-60 is a DB-15 to 15 pin Molex connector they sell. Not sure it'll do anything for you. Easier to just purchase a DB-15 connector and roll your own.
AK9R
Staff member
Super Moderator
Central Indiana
The bigger issue may be the GPS receiver. There are virtually no GPS receivers marketed to regular consumers these days that have RS-232 serial ports. There are some marine GPS receivers have have RS-232 and there are also "puck style" GPS receivers (no screen or user interface) that have RS-232.
Kenwood still sells GPS receivers for their older (non-G model) and other radios.
GPS15XL-W, a Garmin internal receiver board lists for $130.25
Most of their newer radios simply have a GPS receiver built in with an antenna jack on the back.
Motoflightmedic
ÆSØ
U.S.A.
I am not trying to interface to a GPS receiver, just to the computer that feeds the sent GPS data to the server.
Arizona
Are you using the KAS-10 or 20 program to show where you assets are at? I just use the KPG-46U cable from the radio to computer for this and it works fine for our set up.
AD0TY
Indiana
If you're using an NX-700/800 for a base for KAS-10 you have to have the gps board installed or it won't work. If using an NX-720/820 you can build a cable. DB15 pins 6(TXD), 7(RXD), 8(RTS), 9(CTS), 15(GND).
If you're using KAS-20, you can't use an NX-700/800 or NX-720/820 you have to use an NXR-710/810, and if you can get it to work, please let me know how. I have Kenwood tech support scratching their heads.
