Leave the bias-t and preamp both out of the circuit completely while you test the FM Trap along with the pager filter!
You may very well find that stations that were weak before you had the FM trap now come in just fine and you don't need a preamp. Honestly, if the FM station is causing your issues, the last thing you should be adding is a preamp! Even a quality preamp more like what Ubbe mentioned from Mini-Circuits or even higher quality can still cause problems because scanners are not known to have the best front ends in them.
Preamps often cause way more problems than they are worth for many users that live in urban areas with lots of RF around. It's not a problem you can see with your eyes so many users don't realize a preamp may be making things much worse.
Now if you live out in the sticks, by all means, give preamps a try and experiment!
In your case, I'd still play with the preamp you just ordered but only after you see what just having the pager and FM filters inline do. For playing, you can just put the preamp at the scanner for now so you would not even need the bias-t. That would be good enough to test with and see if it seems to help or not.
I'd probably not plan on keeping it though after seeing its specs that Ubbe posted. I had no idea Stridsberg's wideband preamp had such poor specs. If you have it coming though, you may as well play with it and see what it does!
Unless Stridsberg changed their design, their preamps are not weather sealed devices. You will need to get creative in mounting it in an watertight enclosure if it does help your signal and you mount it at the antenna and use the bias-t to pump power up the coax.
As to your question, I can't think of a Minicircuits preamp that would benefit scanner users that can be powered over the coax. I can't say I really looked for that feature though so them may have something. As to other filters, todays world of cheap SDR based tv tuner sticks have a bunch of accessory preamps made for them that can be powered by your bias-t. With an SDR receiver, those preamps would usually be powered by the same 5 volts from the USB bus that powers the SDR stick but there is nothing that says you need an SDR stick to use them. You would just send 5 volts or whatever they are designed for up the coax instead of whatever the stridsberg preamp needed. Adapters to get from SMA connectors which are common on SDR devices would also be needed to connect with the preamps made for the SDR world and your existing coax fittings. Like the stridsberg preamp though, many of the preamps and filters made for SDR users world are not in any case or housing at all so you need to be creative again and waterseal them in the least!
I think they sell preamps made for SDR users that use the same P103 RF amp chip that the Minicircuits preamp uses that
@Ubbe mentioned. That could save money as long as you have a way to weatherproof the thing. It would basically have the same specs as Ubbe listed for the Minicircuits preamp as long as its based on the P103 RF amp.
