Severe Weather Again? 4-9-08
tulsa okla.
#2
hey
this was from normans 10 oclock afd tuesday night,,,,,DEVELOPING NEGATIVE-TILT TROF OUT W... WITH UPSTREAM 160-KT JET
MAX DIGGING INTO ITS BACK SIDE... HAS THE POTENTIAL TO SET OFF A
MAJOR SEVERE WEATHER OUTBREAK WED-THU AS IT SWINGS FROM TX TOWARD THE
LOWER/MID MS VALLEY. DEPTH AND QUALITY OF LOW LEVEL MOISTURE WILL BE
CRUCIAL... ESPECIALLY AS FAR N AND NW AS OUR CWA WHERE THERE IS
STILL A LOT OF WORK TO BE DONE IN TERMS OF LL MOISTURE/
INSTABILITY. IF INSTABILITY BECOMES ADEQUATE... THE SYNOPTIC-SCALE
SETUP SUGGESTS THAT THIS ONE COULD RIVAL SOME OF THE MORE
NOTORIOUS APRIL OUTBREAKS OF THE LAST SEVERAL DECADES. 24
Tulsa, OK
#5
Southeastern OK is getting hammered pretty good; Is it just me, or does KTUL's weather team seem less confident without Travis Myer? :D "uhh so we're showing alot of rotation, and uhh our spotters are reporting lots of debris in the air and flashes from power lines, so uhhh.... if your listening you might want to take cover."
Tulsa, Oklahoma
#6
Well it's 23:30 hours here in Stillwater and it looks like several more rounds of storms are on the way! This has turned into a flooding event and I fear for the worse later tonight and early this morning. Listening to Stillwater PD and FD, OSU PD, Payne SO, Perkins/Iowa Tribe PD, and Emergency Managment. All I can say is wow, what a storm system! All the calls are water related. Jeeez.
#9
hrmm, its looking more and more like the flood we had here not even a year ago. Lets see how long it takes before the Corps of Engineers to react to this one.
