One word...jealous!
Awesome setup there. Very well done! Kudos!
Do you have a link(s) to the parts for where you purchased the rack from?
Cheers! Dave
Thank you.Yes sir and thanks so much! And for Mancow:
Rack: I used the 8U 2 post - looks questionable but turned out to be perfect. Sturdier frame but 16 U if you prefer is on same page.
https://www.amazon.com/gp/product/B01NBPL8OP/ref=oh_aui_detailpage_o04_s02?ie=UTF8&psc=1
Supports 100 lbs - I have about 60 max on mine and it's rock solid. Comes with screws and clips. BE AWARE - top of posts are pretty sharp edges.
Be sure to use the bottom front plate for stability, leave screws semi-tight until you level posts, add racks and radios as you go up then tighten the front facing rack screws once all is level/square. (If you use a screw gun - the screws are a bit soft and will leave sharp edges if anything beyond hand power. You can buy additional screws/clips, got an extra bag just in case.)
Shelves:
Lower two shelves: I used two 10.5" deep NavePoint Cantilever Server Shelf Vented Shelves Rack Mount 19" 1U Black for the AOR/scanners and the Icom IC-R8600's especially because they allow the 8600's to just barely fit side by side. I put small, flat rubber bumpers inside each rack side to protect the 8600's from rubbing the shelves sides and the same bumpers on one 8600 between them being careful not to block any holes in the 8600's sides. I keep a battery fan on the 8600's to keep air circulating and they run very cool all day long.
https://www.amazon.com/gp/product/B008LUW45K/ref=oh_aui_detailpage_o04_s01?ie=UTF8&psc=1
Top shelf is a 2U Rosewill 2U 10" deep Universal Vented Rack Mount Server Shelf for 19 Inch Server Racks/Cantilever Server - a bit sturdier 2U shelf to secure at top and lock it all in place nice and square, and holds the IC-R75 depth perfectly, Icom SP39AD speaker and NetSDR etc.
https://www.amazon.com/gp/product/B06XDWGWTM/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
Rubber bumpers - you can always find use for these.
https://www.amazon.com/gp/product/B06XCLYL53/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
PM or message me if anything you need at all.
John
Nice installation. Curious as to what you listen to on HF.
Very nice! What are your monitoring interests? Also what antennas are hooked up here?
WOW! That's a nice setup!
I ordered two to go side by side. The picture in the Amazon ad makes it look like it tilts back a bit. Is that correct or is it straight up and down?
