Sharkee
ScanWI
MN & WI DB Admin
Wisconsin
It really depends on your use. I have used in a Law Enforcement setting and it works great for stealth applications. The performance is good but not as good as the gain antennas out there, understandably. We used a wideband VHF, with the cellular, and GPS antenna and it has been great. For the local department.
DisasterGuy
Maryland Shore
We have started to use these in law enforcement with good results. The single setup supports the radio, AVL, and MDT. It works out cheaper than using separate antennas.
KevinC
Other
Super Moderator
Home
I received mine, haven't mounted it yet though. I really like the size of it.
I plan on using the internal for the 7/800 only radio and the tri-band whip and a diplexer for the VHF/7/800 APX.
