Shawnee Mountain
LehighValley/Poconos Pa
#2
Best suggestion would be is to check the FCC Database and just plug in all frequencies that might be licensed to them:
Shawnee Mountain KNHQ339
464.9750
464.8750 (Believe might be PL186.2?)
Shawnee Development WNIK866
464.5250 (location ski lodge)
INTERVAL MANAGEMENT INC (Shawnee - WNJW265)
464.3250
INTERVAL MANAGEMENT INC (Shawnee - WNQR565)
464.4750
I did the leg work for you, check on DPL/PL and try and figure out usage if you are going up for some scanning. When going away some place the FCC Database is my first check. Look up the place zip code and type that in the search column. Some zips depending on how big may take you longer but its worth the time. That's my bad thing when going away or some place new; Checking the database and radioreference or course.
Good Luck and please post any findings...
Steve
