Should a P25 conventional freq be set as AUTO
AggieCon
Texas
#2
P25 Conventional Objects in EZ Scan
As of the time of this post, conventional P25 digital objects should be programmed with a "Mode" of "AUTO" in EZ Scan. If you want to hear digital only on the frequency, you may set the "DMode" to "Digital." That might also be helpful if you get a lot of "digital buzz" on the frequency (i.e. the radio is not correctly detecting digital). Otherwise, I recommend a DMode of "Auto" so you don't miss anything. Of course, you can also set a Network Access Code (NAC) tone for squelch.
