Shutting off Wifi (and/or detecting)
scanmanmi
Central Michigan
#1
I would like to disable my wifi signal but in the settings it says something like Broadcast SSID on/off. If I click off will it still be transmitting something just not the SSID? Is there some cheap way of detecting it's transmissions? SDRs don't go that high.
MD - Eastern Shore
#2
That setting doesn't turn off WiFi, it just turns off broadcasting your SSID. A person driving by looking for a WiFi signal wouldn't see it, but someone who knew it was there could still access the WiFi signal. If you have devices that have already connected to that WiFi, they'll remember the connection information even if you turn off broadcasting.
Hope this helps.
scanmanmi
Central Michigan
#3
So I need to get a regular router and then physically power up the wifi when I need it. Does anybody make a wifi that actually shuts off? What kind of 'sniffer' can I detect it with?
MD - Eastern Shore
#4
Okay, I was hoping somebody with more knowledge than me would chime in and answer your question. Alas, no one has, so I'll give it a try, but remember I'm probably not the best person to be answering these questions.
I'm pretty sure there are routers that have a physical WiFi switch, I just don't know which ones. All the routers that I've dealt with have a software switch to turn of WiFi. You have to log onto the router, find that setting, then toggle it on/off. The downside of this is that you'll need a hardwired (Ethernet cable) connection to the router to turn it back on.
An alternative solution would be to use a dedicated modem and separate routers. You would need a dedicated modem (one that doesn't have a built in router), a router without WiFi and a router with WiFi. You would connect the router without WiFi to the dedicated modem and then daisy-chain the router with WiFi to the first router. With this method, when you need WiFi you would turn on the router with WiFi, and when you don't need WiFi you would turn it off.
There are "sniffer" apps available, but I've never used them and can't really recommend one. From what I've heard, they are just some software that you run on your laptop.
I know this probably doesn't help a lot, but maybe by bumping this thread someone with more knowledge than me will chime in.
RLG, Fly heading 053, intercept 315 DVV
#6
What model and brand of router do you have?
What is your goal?
There should be a switch in the router firmware to turn off the WIFI signal.
It doesn't matter if you broadcast a SSID or not. The network can be seen in WIFI cracking software.
To see WIFI you need a HackRF.
#10
If you go to the wireless settings in the router and select disabled for the network mode that should disable the radio. But I'm not sure if that leaves 5 GHz enabled or not. The only way to test that is to use another computer with WIFI that has 5 GHz capability and see if your SSID shows up or not.
#12
There's no check box looking at the manual. It's the option under the WIFI options called "network mode" that needs to be set to disabled.
But reading the manual seems to indicate perhaps doing this will still allow 5 GHz, though I'm not sure. To confirm this you need a WIFI card capable of 5 GHz and see if your SSID still shows up. If OP doesn't have a 5 GHz capable WIFI card, then this USB dongle will suffice for testing absent of a very expensive HackRF SDR. 600 Mbps Dual Band 2.4/5Ghz Wireless USB WiFi Network Adapter w/Antenna 802.11AC | eBay
MD - Eastern Shore
#13
poltergeisty is right, this is how to turn off WiFi on this router. And, FYI, it does disable both bands. But, word of warning - you will need a wired (ethernet cable) connection to turn it back on.
MD - Eastern Shore
#15
When I read this bit I was a little confused. It seems like from what it says that if it's disabled, you still have 5 GHz. Even more cryptic is that it says 802.11 N will be disabled, but doesn't mention 5 GHz but 2.4 GHz. 802.11n can use both bands.
That confused me too until I looked at Linksys Support page and saw this image in the installation instructions:
It looks like this router has a different set of settings for each band, both of which can be disabled.
