Sorry, when my company does tech support, we always need the baseline specs explicitly stated to avoid assumptions. Knowing what background processes are running is also helpful. Are you using one or two RTL-SDRs? What are the parameters you are using to start the program? What is the radio system you are trying to monitor?
I can hear a "stutter-like" anomaly when listening to your recording. I will try to duplicate your setup on a nearby phase 2 system around here to see if I can duplicate the behavior.
I have been changing as few parameters as possible since after I uploaded those videos to be proactive.
Some changes:
added -a0 to stop FMP24 from auto correcting. It wasn't staying centered when tuning to 12.5khz channels
manually adjust ppm. best i found was 0.4ppm active keys p/P. It looks centered. Really hard to get perfect center on various frequencies.
Experimented with RF bandpass tightness between standard and tight for 9.5khz and 12.5khz using FMP24 active key T', No change.
Software defined Radios: Nooelec NESDRSmart, NanoSDR, Flightaware Orange RTLSDR with built in LNA(this one overloads signals at 850mhz even at 7db) I use single dongle configuration.
My custom batch file for to run DSD FL and FMP24 with one double click:
START DSDPlus.exe -r1 -e -T -E -i20001 -O NUL -v1
START FMP24.exe -rc -i0 -o20001 -a0 -P0.0 -g14.4 -f851.1875
Ensured TCP 20001 in windows firewall port exceptions
Ensured both FMP24 and DSDplus.exe are in the firewall exceptions
CPU scales up to 3.5ghz. only when needed it boosts frequency. It hovers at 2.48ghz when DSD+FL is running. Base frequency is 1.5ghz.
CPU load FMP24.exe 1.5% & 15mb RAM usage
CPU load Dsdplus.exe 1.4% & 19.5mb RAM usage
Overall cpu usage with all other system interrupts and background services 10% with 71 total processes total memory usage 3.1GB/8GB
Intel core i7 10TH Gen (4 cores 8 threads)
System memory 8GB (windows reports 3200mhz)
SSD 512GB (nvme) with Intel Optane 32GB enabled (system optimization nothing pinned yet)
64bit system Windows 10 1909
2x USB 3.1 ports
(no usb 2.0 at all)
All Intel chipset except Realtek HD Audio(connected) & RealteK PCIe GBe Ethernet adaptor.
HDMI Intel Display Audio (not connected)
Intel Iris Graphics Plus 128mb VRAM shared 1GB (can use 4GB shared) (not related to issue)
I hope this is enough.
Reminder the stutter is only on P25 PII TDMA
P25 P1 sounds good
DMR sound good
