Signal Codes
georgiat28
Goldsboro, NC
On my scanner I hear different Signal Codes. Where can I get a copy of Signal Codes (example signal 29V or I just heard 12Delta2Edward)? I have a copy of 10 codes
Maple Hill NC
12D2E is an EMD code, dispatch codes used for EMS systems that use the Emergency Medical Dispatch protocol. You can search EMD codes on Google, and find plenty of results. Some EMS systems vary slightly and have their own codes altogether though, so keep that in mind.
On a lot of the communications systems these days, 10-codes aren't used very much, but it seems that law enforcement still uses them quite a bit in most areas.
ncdadof3
Morganton NC
Did you find the EMD codes? If not let me know and I will get a list for you.
