Yesterday morning around 0900 EDT (1300 UTC) I stumbled across these strange transmissions that seemed to drown out WWV entirely. It started again this morning while I was writing this thread. I first noticed it this morning at 0915 EDT (1315 UTC).
It looks (on spectrogram) and sounds to me like some sort of MFSK. As you can see in the band-scope images, the signal is present at the same position relative to WWV on both 5 MHz and 10 MHz, and the bandwidth of both signals is the same. As you can also see in the spectrogram images, it appears to be the same exact signal as well. For the same signal to be present in the same relative position on two different bands, my theory is that it was deliberate.
Twenty minutes ago, I was able to hear WWV just fine on 5 MHz. Now all I hear is the same buzzing you will hear in the 5 MHz sound file below.
Here are the band-scope images, lower frequency first:
Here are the spectrogram images, lower frequency first:
Finally, here are the audio recordings, lower frequency first:
Freesound.org - "5mhz_jam.wav" by dark_overload
Freesound.org - "10mhz_jam.wav" by dark_overload
I have racked my brain trying to figure out what in the world this could be, and the best I can come up with is that it is some foreign military's attempt to jam our standard time signals. The fact that it sounds like innocuous noise to the untrained ear, and the fact that I cannot decode it no matter how hard I try, even in spite of the fact that it is clearly a digital transmission of some sort, is what lead me to this conclusion. I am open to other ideas so please, if you have anything to contribute, let me know what you think.
Also, as I am hearing this right now, completely drowning out WWV on 5 MHz, and overlapping WWV on 10 MHz, please let me know if you hear this signal as well, or have heard it in the past. I would like to try and find out if this is a local source of noise or what. I live in FL though, so for all I know it might be coming from Cuba.
