I found this closed thread regarding using 2 germanium diodes & 2 ceramic caps used to produce a voltage for a signal level meter;
forums.radioreference.com
The problem is I don't know the exact diode numbers used since no one in that tread showed it in any post other than a photo which doesn't help.
The point I used on two different 2004's was TP5 inside the shielded compartment towards the front of the unit, which I have to figure was Bill Cheeks circuit.
I want to do the same thing on a 2006, but the only SS meter circuit I found is using D33 via a 10k resistor and a ceramic cap to ground which DIDN'T work! (All I got was a 1.5v negative voltage with a signal received.)
Pro-2042 signal strength meter mod
The Pro-2035 and 2042 were great scanners, and continue to be useful for aircraft monitoring among other things. They, like their predecessors, ( 2004,5,6 ) fell short in a few areas. One of those was not having a way to visualize the relative strength of the incoming signals. Enter Bill Cheek (...
