WS1040: Signal meter indicating signal
garyw1nc
I programed my 1040 today and it was working great and then did more down loading the signal meter will hardly move. Radio Shack in same location is picking up good with strong meter indication signal. Is there a setting that I am missing? I have adjusted sq. no change.
tumegpc
Southern Oregon
If I'm remembering correctly , In Win500 software - under Extended Settings there's an option to adjust the RSSI Bar Thresholds.
Blackswan73
Central Indiana
No, same as a 106, 651, and GRE 500. The 197 is the same basic radio, but in a base/mobile configuration, and is the same as the 652, GRE 600, and Whistler 1065
NDRADIONUT
FARGO ND
Ok the rssi works the same then.... I saw some other thread about the levels being set way off on a unit right out of the box....
basstuba
no signal bars whstlr 1040
I am having the same issue no signal bar showing up new unit out of box but and old pro106 has signal bars .is this a defective unit.the radio does pick up.
TAbirdman
MO
its not defective. if you took an old GRE radio and cloned it to the Whistler for example, the meter settings will change to the GRE and have the meter not work.
to change:
PGM/Func/F3 then scroll down to RSSI Bar 1 setting
bar 1 should be 190
bar 2 - 230
bar 3 - 260
bar 4 - 290
bar 5 - 320
basstuba
That did the trick,just put the numbers in win500.now if someone can add this to winki on this site.
bheisner
Silver Spring, MD
to change:
bar 1 should be 190
bar 2 - 230
bar 3 - 260
bar 4 - 290
bar 5 - 320
Thanks! I had the same issue. The S-meter is working perfectly now with those bar values.
BTW, out of the box, my Whistler WS-1040 was set as follows:
bar1 370
bar2 450
bar3 520
bar4 610
bar5 680
Those values are way too high and the meter didn't even function.
I never had this issue with my Pro-106 or PSR500.
zac
Albertville, Alabama
i have two ws1040 scanners. one my friends the signal is strong multiple bars however on mine its showing like one bar maybe. any suggestions on why and what to do?
mikey60
Oakland County Michigan
Many of the components that were used in the PRO-106/197 and PSR-500/600 were no longer available when Whistler was looking at rolling out their versions of these radios. Many of the circuits had to be redesigned which means that some of the values for RSSI changed. This is why PSREdit500 has two buttons for setting the default values for these.
The values listed above (190,230,260,290,320) are correct for the PRO-651/652 and WS-1065/1040.
Mike
zac
Yea mine were off. Brand new scanner purchased last week. He bought his few months ago and had correct setting. Which made no sense to me.
racing1
I thought the RSSI valves were for display purposes only not to change the actually performance of the scanner.
Sent from my SM-G955U using Tapatalk
djeplett
NE Wisconsin
They do not change performance in any way. They are to adjust the amount of signal bars shown only. I have adjusted mine on my PRO-106, my PSR-500 and my TRX-1 as the stock values for me never differentiated enough between marginal and good signals. YMMV
Sent from my VS988 using Tapatalk
