Signal Strength Displayed by SDR#
wxgeek99
Mount Juliet,TN
I like to send out some signal reports when hear a long distance station. However SDR# does not have a conventional S-meter. The scale goes from 0dB to -120dB. Not sure how to translate that into an S-meter type reading. Any ideas/suggestions?
Jimmy
mbott
EN80nd
From the Wiki on S Meter. Might be helpful.
Mike
VHFgeraint
I don't think that you can relate the Y-scale reading in SDR# to an S-meter reading. I suspect that the scale is dB relative to full scale on the ADC. As mbott suggests, an S-meter measures signal strength at the receiver input
mbott
EN80nd
From my experience with it, it does not provide an accurate S-meter reading. I have it installed, but I do not use it.
Mike
jonohudson
Bedford, UK
Accurate signal level measurement using SDR
SDRuno together with the SDRplay RSP1A, RSP2 or RSP2pro provides accurate signal strength measurement as demonstrated here (an RSP2 example): https://www.rs-online.com/designspark/highly-versatile-rf-power-measurement-using-the-sdrplay-rsp2
You can even use SDRuno as a datalogger for monitoring or charting purposes whereby you can write the measurements to a .csv file https://www.rs-online.com/designspa...ogging-accurate-rf-power-and-snr-measurements
Best regards, Jon
