Simple but effective DIY civil/mil airband antenna the "double bazooka"
W5lz
The "secret" to antennas in this freq range is height! The higher the better.
W5lz
Should have included this above... only mistake I've made all year! (You believe that, right?)
The other "secret" is to make the/an antenna as resonant as is practical (not as possible, but practical). Resonance equates to efficiency (sort of), and that efficiency is desirable in most cases (not all, but in most cases). There always seems to be a "gotcha" with this stuff ain't there?
krokus
Southeastern Michigan
The drain hole is a good idea, but would suggest smaller holes, or a small patch of fiberglass window screen applied over the hole, to prevent insects from entering the antenna housing.
Sent using Tapatalk
W5lz
The "bazooka" (single or bouble) antenna has been around for over 50 - 60 years. It works, but don't hold your breath for 'miracles'. They also have a few draw-backs depending on design frequency, as they get heavy and sort of expensive. Even at VHF/UHF frequencies you don't see very many of them. Ever wonder wmy? I got a hole out of a donut I'm willing to bet that it has to do with efficiency. Wanna bet?
radiostationx
Near Liverpool,UK
I see plenty of commercial airband VHF and UHF folded dipoles, they are heavier, ...nothing fantastic and they have holes in the middle as well.
Oh and they are more expensive, willing to bet the hole and the weight has something to do with maintenance, the xtra expense well thats for the weight of the hole or "good ol nickel and diming" the client.
prcguy
In the US I see mostly ground planes, Discones, coaxial dipoles and fat dipoles inside radomes for base station aviation use but I can't say I seen a single folded dipole for the same. There is no reason you can't but apparently its just not popular here.
prcguy
Something I would like to know about these is if they are actual folded half wave dipoles which are about 200 ohm impedance and would need a matching circuit, or if they are half wave dipoles with the elements folded back to ground in the middle on both sides, which are about 50 ohms. The folded grounded versions are the most common in the US and are fed directly with 50 ohm coax or when stacked, a phasing harness that is 50 ohms at each element.
The advertising for the Web antennas states the metal parts are DC grounded, which makes me think they are not true folded dipoles.
W5lz
A bazooka type antenna is basically a half wave doublet fed through a matching network. The straight-through center conductor is the doublet part, the shielding on it is the matching network. Sort of an odd shaped "Y" fed dipole. The 'spread' between the two outer contact points of the shield with the center conductor amounts to a static and variable impedance matching system (How z'at for an analogy!). It's 'static' cause it's fixed in place, and 'variable' because of the amount of impedance change with the change in frequency, which almost stays constant.
[Ever noticed that engineers (mechanical and electrical) always have gallons of aspirin around? It's 'cause of concepts like this.]
Is this -THE- way of thinking about this? Jeez, I hope not, but it works for me...
krokus
radiostationx
Near Liverpool,UK
That looks nice, but was curious if the center attachment area has the same amount stripped? (15 to 20 mm.)
Hi krokus,
Good Question.
Yes around 15mm of sheath and braid was stripped back for the centre connections but you cannot see the dielectric or solder joints on this one.
I threaded on the heat shrink (2pcs) first but slid them futher away from the box centre towards the ends and kept it out of the way while making solder joints in the middle. Then I slid back the heat shrinks back over the pigtails so that the 2 yellow sleeves met in the centre, then it was a hair drier job to shrink it all down .
