Simple Question re: Motorola 7550
LZJSR
California
#1
Simple question: My organization uses a conventional VHF analog radio system between 150-175mhz (public safety). Will this radio be able to be used for a conventional system, or only on MOTOTRBO and/or digital systems?
Thanks in advance.
In the 'patch
#2
Thanks in advance.
The XPR7550 is capable of analogue operation
#5
Ensure also your agency will not switch to a different digital format down road within reasonable time. Say you get a trbo radio capable of analog and your agency uses analog now but in 1 year or 3 decides to go to p25. This can help save some money.
