n211cr
I know through icecast you can add additional mount points for other streams. How do you set this up through SimpleCast? I am using Windows 2000 so I have each sound card has to be used independly. I have 1 that currently feeds SimpleCast, another that uses Xcorder to record that same stream, and a third with a 2nd feed that I am trying to feed through IceCast. I can use something other than simplecast to encode if someone can tell me that its going to be possible while not having to change the windows default recording sound card. Xcorder has to have that set for it.
Thanks.
Thanks.
