foggymoon
Can someone please explain what simplex channels are and how they are used
The Wiki is your friend. Lou Maag, one of the Moderators on RR has a good explanation of simplex which is slightly longer than Gilligan's.Can someone please explain what simplex channels are and how they are used
Thanks for the info. Is it a good idea to use these frequencys and if so how do you program them into the scanner with the software?
It is always good to have freqs to listen to, even though you won't hear them too well unless you are close to them. Just enter the conventional freqs just like you would any other conventional freqs, no special need for them unless you see they are using different 'pl' tones and them you must make sure you enter those. (if your scanner has the capability)
Take care.
It depends on what radio you are using. If the radio has an option of just leaving the CT/DC/NAC to search or auto then leave it at that.rvictor
So when I enter a simplex channel into the software manually do I choose a auto tone? What do I choose for tone?
not all radios have pl lock out. It is a great feature if you have it
