Whospoonbill
- Joined
- Jun 4, 2015
- Messages
- 332
Is the 325 or 436 good in manor Texas or do I need to spend $600 on the sds100
Hopefully, someone in the Austin area can give you more specific information on any simulcast issues in Travis County. That being said, while the 325P2 is a good scanner, simulcast is it's Achilles heel. The 436HP is marginally better, but if you are in a severe simulcast area, the SDS series scanners, the Blue Tail Receiver, the Unication pagers, or (if you are in a fixed location, not planning to go mobile) use a PC with a couple of SDR dongles to receive GATRRS are better choices if simulcast problems are present.Is the 325 or 436 good in manor Texas or do I need to spend $600 on the sds100
There's no way anyone can positively guarantee that you'll never have a problem with any electronic device. (That applies to vehicles as well. Recalls are a fact of life at your local auto dealer.) Have there been issues with the SDS series scanners? Yes. But the problems, however many, or few, that there are, are what gets exposure, not the ones that work correctly. My SDS100 & SDS200 were among the first units sold and shipped. To date, I have no issues with either. No hum, no loss of reception due to the infamous cold solder joints, no display issues, nothing. That's due, partly, to PDL, not any skill & control on my part. If I decided I needed to add yet another scanner, I'd have no qualms about buying an another SDS series scanner.What about these reviews I’m reading I heard the sds100 after 2 weeks of operation it just stops working know I’m begging to think it it’s even worth it
Your options, if simulcast really is a problem at your location, remain the same as I noted in post #2.
Get an SDS series scanner
Get a Unication pager
Get a Blue Tail receiver
Or get a couple of SDRs, download the free software, and utilize your PC.
Amazon has one of the most 'buyer friendly' return policies, no restock fees. However, at this time, the only seller at the "normal" price for the SDS100 indicates that there are only 3 in stock. There are two other sellers listed, but both have inflated prices.So what’s the best place to get my sds100 from is amazon good zip scanners bearcat warehouse website
Unless you plan to only use the 436HP (or the base/mobile version, 536HP) at home, where you can possibly rig an antenna setup to counter simulcast, you would be disappointed with either of those scanners if out & about driving around the Austin area. Simulcast will definitely cause you issues hearing the system.My only fear is I don’t want a scanner that gonna break down I had still have my 125at and I’ve dropped it, it’s been snowed, rained on, anything you can think of and it still works I heard the sds100 works with water proof but idk I’m not worried about dropping it it’s in a Motorola case xts but I want it to last long just like my 125at and the orange screen is starting getting old I’m sure this scanner I have rn will last another 10 years or so there been some batteries issue but I fix it I want to get the 436 but I don’t have a vehicle to send it back if it doesn’t work the main thing is if the scanner I get is tuff enough to because be treated like a actually police radio
You have to take those reviews with a grain of salt. I purchased a used SDS100 and its been working great for over a year plus however long the previous owner had it.What about these reviews I’m reading I heard the sds100 after 2 weeks of operation it just stops working know I’m begging to think it it’s even worth it
Leander is farther away from central Austin (and Simulcast 1) than Manor is. While I have a TRX-1, it is generally useless on the simulcast systems that dot the DFW area, unless I'm far enough away to let it pick up only one tower location.In Leander, Simulcast 1 site too far away for good reception, Honeycomb and Williamson come in perfect Whistler Trx1.. Also listen to airband my main interests..using longwire antenna directly connected to bnc..Try Trx1..
