If installing a discone antenna on the same mast as Tv antenna how far apart from each other?
S superpriesty Member Joined Nov 17, 2018 Messages 11 Location SE Wisconsin Jan 31, 2019 #1 If installing a discone antenna on the same mast as Tv antenna how far apart from each other?
mmckenna I ♥ Ø Joined Jul 27, 2005 Messages 23,889 Location Roaming the Intermountain West Jan 31, 2019 #2 Are you transmitting with the discone or just receiving?
S superpriesty Member Joined Nov 17, 2018 Messages 11 Location SE Wisconsin Jan 31, 2019 #3 mmckenna said: Are you transmitting with the discone or just receiving? Click to expand... Just receiving!
mmckenna I ♥ Ø Joined Jul 27, 2005 Messages 23,889 Location Roaming the Intermountain West Jan 31, 2019 #4 Usually the way to do this in your application is to put the discone at the top of the mast. Put the TV antenna a foot or two below the bottom of the discone radials.
S superpriesty Member Joined Nov 17, 2018 Messages 11 Location SE Wisconsin Jan 31, 2019 #5 mmckenna said: Usually the way to do this in your application is to put the discone at the top of the mast. Put the TV antenna a foot or two below the bottom of the discone radials. Click to expand... Thanks!
