Works for me on an iPhone Xs. The audio lags by about 1.5 seconds tho. Didn't play with it long enough to see how stable it was.
good I have a xs as well
Has anybody ever tried the dongle that worked on the BCD 536
The scanner probably doesn’t have the menu items to connect it to a wireless network..
Sent from my iPad using Tapatalk Pro
If you plug in the bcd536 dongle to the USB port on the front I wonder if it would obtain an Ip-address. I betting it won’t, but maybe someone on the forum here can try it.
No, the WiFi dongle doesn't work with the SDS-200.
It worked for me right away on my iPhone XS
Do you have connection and audio all the time. What device are you using to connect WiFi to the LAN port on the sds200?
Yes connection all the time I set a static in my router so that it gets the same IP every time
I have a Cisco wumc710 wireless bridge
That I use to connect it to WiFi
Sent from my iPhone using Tapatalk Pro
Can confirm Siren works fine with SDS200. All I did was hook up network jack to router, set for DHCP automatic IP. Entered the new IP into Siren and it works fine throughout my network. Using Siren on a android phone.
I had to change the 200 to be Manually configured, including IP, DNS etc...
That allowed the Siren app on my iPad and iPhone to connect.
No Audio on the iPad however, and pressing the app's Mute button will crash the app...
