I can't get audio on a consistent basis. Siren always connects to scanner and I can control the scanner
but not always audio. Something I am missing??
Currently set as DHCP and FTP enabled as read only.
Was going to try a static IP but didn't know what port number(s) to set in my router.
You do not need to set it as static in the router (unlike the 536 that one must), note what the current IP is set in the SDS using DHCP, then set that address as static in the SDS.
Are you able to access ALL favorites list through the app? On both iPad mini 4 and iPhone since 5S can only access the first nineI still use it with the 536 and it works fine..
Sent from my iPhone
Update, it was doing good at first then it lost audio multiple times
Sent from my iPhone using Tapatalk Pro
I feel like if they updated the application I would actually pay for it
