Site 08 OKC OKWIN
Ada, Oklahoma
#1
In the database there is only one control channel 857.9375c for site 08 Oklahoma City The OKWIN site map https://www.ok.gov/okwin/ shows 3 sites for Oklahoma City OKC (Prime) OKC (SE) OKC (Moore) They should be a separate control channel for each site . Does anyone have any info of the control channels ?
n5bew1
norman, ok
#2
I took a listen on all the 4 listed possible control channels with my 14 element 800 Mhz log periodic beam pointed basically north from here in east Norman and I only hear one control channel right now on 860.9375. It seems if DPS was using a different control channel from say Moore I'd hear it from their 450 ft tower up on NE 36th.
Ada, Oklahoma
#3
When I was in OKC The other day I was hearing the OKC traffic on the Norman 860.9625 but nothing from site 08 on my Motorola XTS3000 HT I have the HT programmed for the OKWIN system I have Lex and Pink, Shawnee both Norman CC's OKC and others I have the site scanning on on the HT I also have my Astro Spectras programmed for the OKWIN ...
