Site roaming NXDN
FARMER522
Can someone please explain the difference between site roaming NXDN and site roaming with ran NXDN ? I'm not getting much out of the help file. Thanks
ramal121
Lots and lots of watts
Calif Whine Country
Well you're not the only one to be a little befuddled and Kenwood hasn't given me a straight answer either.
If your read through the function description it basically does the same thing for both. I'm thinking it has to do with the speed at which it can scan to find the site with the best RSSI. If one is slower you may have to jigger other site roam parameters to get it to play right. Maybe run the beacon timing out a little. Co-channel users or systems may also dictate whether one choice is better than the others. The correlation (I think) is kinda like AC Control in conventional scan.
I'm running a system and just took a stab at setting Site Roam with RAN and it seems to play fine.
