SITOR-B Software Decoders
eorange
♦RF Enabled Member♦
Cleveland, OH
What are people here actually using to decode SITOR-B?
I downloaded the NAVTEX decoder (forget the name), which I understand is the same as SITOR-B.
I also upgraded to the most recent version of MultiPSK (been using MultiPSK for a long time), and now I notice it specifically has a button for SITOR-A. But not B? Which is what most UTE transmissions use?
Note: I haven't actually tried to decode any SITOR-B yet; just want to hedge my chances with the software that will most likely do it well.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
When I want to read the USCG Boston broadcasts, I usually use MixW. However, I just checked MultiPSK version 3.9, and it lists NAVTEX as one of the modes, so if you have that version you ought to be good to go.
73s Mike
eorange
♦RF Enabled Member♦
Cleveland, OH
I'm at MultiPSK 4.4.2 (I think that's the newest), so I'll check that out that.
To confirm: NAVTEX = SITOR-B?
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Close enough - as I understand it, NAVTEX has headers on each message that contains date/time stamps and originating station information. A commercial reader can check these timestamps and see if a duplicate message is being received - if it is, it's ignored.
Reading a SITOR-B signal with NAVTEX should work just fine - I'm pretty sure the protocols are the same, with that one slight difference. 73s Mike
[edit] By the way, there's a dedicated MultiPSK Yahoo group now, and Patrick is there quite frequently.
