SLC Airport Authority System
gldavis
Bountiful, UT
Salt Lake City Airport Authority
----- I sent to Tim----
I suggest removal of this system from the database. 11 of the freqs listed are now part of the Salt Lake City Public Safety System (AC33). One of the freqs is part of UCAN, and the other 2 are not being used, locally.
Keeping this system, as it is in the Database, is creating confusion with the PRO-107/ISCAN download Library. If you load the Airport Auth system into your 107, then scanner sees SLC PS traffic as Airport traffic with different TG's.
-----Tim Replied back with -----
Hi Gary. So is there anything that needs to be saved or converted to AC33 from this system? This sounds like something we should run by the forum for comments first. Can you post your proposal there?
-Tim
Any Comments?
mrlthse
Layton, Utah
If ya removed...
QUESTION:
If we removed this data information can these talk groups still be monitored for those who choose...
kd7rto
Bountiful, Ut
I'm still seeing a control channel on 858.4875. My advice would be to hold off on deleting the entry until the system is completely off the air. I'll monitor with trunker today to determine which frequencies and which talkgroups (if any) are still in use.
kd7rto
Bountiful, Ut
There's not much left on this system, but there still are a couple of active groups. I think the database should be updated, rather than deleting this system from it.
From 1 days worth of monitoring:
Airport
MAP=2???????
OPTIONS=nVDf
PLAN=8
DESCR=Type II 76.76 Hz
THRESHOLD=50
DISPOSITION=abcbdbebfulxnbpbsr
c v855.4875,b3,ffff,231a
v857.2625,fa,ffff,2104
v858.2625,122,ffff,1c1b
d 858.4875,12b,ffff,0
;VER=3
;ID_hex,COLOR_dec,PRIO_dec,TITLE_str,LASTNOTED_hex,HITS_hex,USAGE_hex,ID_dec,ID_str,LASTNOTED_mm/dd/yyyy,LASTNOTED_hh:mm
00d0,7,0,"?",4b550428,1,0,208, 208,01/18/2010,20:00
0190,7,0,"?",4b547058,0,0,400, 400,01/18/2010,09:29
0470,7,0,"?",4b550832,8,0,1136, 1136,01/18/2010,20:17
0490,7,0,"parking",4b55245b,188,0,1168, 1168,01/18/2010,22:17
0870,7,0,"?",4b54c724,51,0,2160, 2160,01/18/2010,15:40
theaton
Member N7VU
Moab, Utah
Thanks for checking this. I removed all the frequencies that were also listed for AC33, which left the four logged by KD7RTO plus 859.48750, which I downgraded to a possible Alt channel. That should eliminate the confusion with AC33. I will be happy to delete more frequencies as well as TGs. Let me know what a few more days of scanning pick up.
I wondered why this system seemed dead when I was in the valley for 2 weeks over Christmas.
-Tim
gldavis
Bountiful, UT
Okay, I've ben running Trunker this week and have the following possible Talk Group ID's :
208 Engineers Ch-2
400 Parking Lot Control
528 Maintenance
1136 EMT Call Out--
1168 Parking Lot Maint--
1232 SLIA PD Disp--
2160 Concessions Ch-1---
2192
48176
48272 Airport Channel
48496
Freqs are 855.4875, 857.2625, 858.2625, 858.4875-cc.
theaton
Member N7VU
Moab, Utah
Thanks Gary. I removed the extraneous frequency and added the TGs you logged that are new. I thought of deleting all the SLC TGs, but you got hits on 48496 that was (is?) SLC Police East (Liberty). -Tim
208 Engineers Ch-2
528 Maintenance
1136 EMT Call Out--
1232 SLIA PD Disp--
2192
48176
48496
gldavis
Bountiful, UT
I would recommend removing all but the TG's I've logged so far. Maybe treat this system as a"new" system.
kd7rto
Bountiful, Ut
I also agree that removing those groups confirmed as having moved to AC33 could spare some unnecessary confusion.
Gary - have the units you have monitored on 1168 just been maintenance, or have you heard parking enforcement as well?
theaton
Member N7VU
Moab, Utah
I'm happy to remove unlogged TGs. I just wonder where they all went and if some are just used infrequently. Are there any suggestions for some I should keep? I'll wait a day for further comments.
-Tim
gldavis
Bountiful, UT
What I've heard the last couple of days is comms dealing with Maint type issues. Primarily equipment not working/damaged. I have not heard any enforcment type comms.
theaton
Member N7VU
Moab, Utah
Hearing no objections, I deleted the TGs that have not been logged recently. Feel free to submit any new TGs that you hear on this system.
-Tim
