SLERS Clay County
PYuknis
Green Cove Springs
#1
1 = control channel. All Pro-voice and does not work with PRO-106 as expected. Monitoring as conventional in SDRSharp with DSD does work. Not all transmissions are encrypted. Control Channel is Site 171.
1 851.9375 WPVU961
2 852.4375 WPVU961
852.4750 WPVU961
852.4875 WPVU961
3 852.9375 WPVU961
4 853.4375 WPVU961
853.4500 WPVU961
853.4875 WPVU961
5 853.9375 WPVU961
853.9500 WPVU961
