Sm50 powered reverse polarity
KYPLOW
West, Kentucky
Friend was installing a sm50 and used a cheap adapter with colors reversed for the power plug now radio won't do anything the m2535l diode fell out in housing I've checked it and it shows good so I re soldered it but still nothing. Where do I look, or is it a lost cause? Thanks in advance.
MATT
cmdrwill
So Cali
The m2535l diode is supposed to blow the fuse in the power cable with reversed polarity, but got way overloaded. No FUSE ...
In some models in that series there is a small fuse on the '12 volt line' to the logic section that blows. But before the big diode blew it self off the board other damage may have already occurred.
kruser
Well Known Member
W St Louis Cnty, MO
Yep, the external fuse(s) should have blown in the power cable well before the diode heated up so much that it fell off the board!
Once that diode fell off the board, the reversed polarity would have passed to the rest of the radio at the full potential of the power supply.
Hopefully the OPs radio did just blow the fuse feeding the logic section.
KYPLOW
West, Kentucky
Thanks fellas, I don't believe there was a fuse in his power cord lol. I didn't see any fuses on the board but I may not know what I'm looking for. Is it a very small glass tube fuse or something similar? I'll try to post a picture when I get in tonight.
com501
Green picofuse that looks like a resistor near the rear accessory connector. Check it with an ohmmeter.
Project25_MASTR
TX-COMU
Texas
You can temporarily short the fuse to bypass (I'd put a fuse on the positive side of the cable lead) it to see if the radio powers up.
KYPLOW
West, Kentucky
That did it!! Hits repeater transmits well receives well. I removed the fuse and put a single strand of wire in its place to check it. All I have to do now is find a fuse lol. I can't thank you guys enough. I know you can buy these radios all day $50-100, but thanks to your all's knowledge I was able to put this one back in service!! Never tried making repairs on anything so tiny before, I'm feeling pretty accomplished. Thanks again. Matt
kruser
Well Known Member
W St Louis Cnty, MO
Glad it worked!
I'd definitely get a new fuse to replace the PICO fuse on the board and also get some inline fuse holders in that power cord!
N4GIX
Hot Springs, AR
This is an excellent reminder to always check a power cable's polarity before connecting power! I recently ordered a replacement power cable for a Kenwood TK-880 I had bought, and when it arrived I noted immediately that the red and black leads were installed in the connector in reverse.
I notified the vendor to advise that they might wish to check their inventory to see if there were any more in stock like the one they sent me. Fortunately it was a trivial matter to reverse the polarity by extracting the pins and reinserting them in the plug correctly.
cmdrwill
So Cali
A very important lesson learned here: Always check the polarity of the power cable FIRST, and make sure you have a proper sized fuse in THE cable.
I believe I also mentioned abut using a small, 2 amp or less, fuse to test a unknown radio.
