I bought an LED for the 3D fix pad on the GPS and may mount that at a later date.
Cool. Thanks for all your help. Now that I have everything finally working, I am partly inclined to leave it be, haha.You actually want a bi-color LED with common cathode.The 3D fix output cycles on and off at a 0.5Hz rate while the module is getting a fix, then shuts off. Once the module has a fix, the PPS output pulses high for 100ms once per second. I use a red/green LED with the green side connected to the 3D Fix output through a 330 ohm resistor, and the PPS output connected to the red side through a 3.3K resistor.
In this configuration, the status LED cycles green on and off while the module is getting a fix, and then blinks red once a fix is achieved. The green side of the LED uses about 3mA, and the red side about 0.3mA.
I'm going to go the route of using a HC-05 Bluetooth module and Max3232 installed in the BCD436 paired with a like HC-05 / GPS module with external antenna installed in my car.
In that scenario, all I need to do is bring the radio with me into the car, and it auto pairs with the GPS module and enables GPS.
Two questions for you, I just bought a "436" to get back into scanning now that I'm retired and was wondering what you charge to install the GPS system you're doing? The second question, do you have a link to your technical support forum.
No dice. I'm cutting a hole in the original back, not a replacement back. The factory belt clip setup is flimsy and I wouldn't recommend using it anyway.
What you really want is a RAM mount with a finger grip holder and whatever mounting hardware is appropriate for your vehicle. Have a look here:
https://www.amazon.com/hz/wishlist/ls/2NBJVGJ2UNPEI?&sort=default
And you might as well get your scanner GPS modded to get rid of as much of the cracked plastic as possible.
Nope, unless I got a clueless phone rep, I was told they don't sell it.
If you have a part number, I'd be glad to take another, more assertive crack at them.
They are glad to have me sent it in and they will replace it.
But, my radio off to Uniden for 4-6 weeks (more?) to take out 4 screws and take <minute...
THAT isn't happening...
