Smallest antenna
SmitHans
Arizona, USA/Sonora, MEX
I've been in CB for years, but was never concerned too much about the antenna size. Now, I'm considering putting a CB in another car, but I really don't want a big antenna on the car.
Does anyone know of a decent CB antenna that is around or less than 18 inches in length? The only ones I've used in the past were the glass mount CB antennas, & those suck. Thanks all.
milkman21218
Baltimore, Maryland
There are no good CB antennas around that size. Just think the antenna should be 102" long with a 6" spring. Total 108" 10 times the length of what you're looking for. And if you are really trying to talk any distance you will need at least 4' to get 3-5 miles. If you want small get a K-30 or Lil Wil. They are the best small antennas. In the CB world Bigger is better!
I think it depends on if you're talking or just want to listen.
If you wanna talk, you're gonna need a good antenna, with at least 3 to 4 foot length to it.
If you're just wanting to hear the truckers up and down the road, a shortie should suffice.
But even the shortie needs to be outside the car. I myself am not aware of any cb antennas made that are shorter than a couple of feet.
SmitHans
Thanks for the links. I don't care about maximum talk distance, 95% of my contacts would be a mile or less. Receive range a bit more important. Don't want this car to be bristling with big antennas. I already have a car like that.
FiveFilter
I have a magnetic-base 35-inch K30 antenna on the trunk lid of my sedan. I cut it to about 32.5-inches to get the SWRs into an effective range for my Mazda's ground plane. The antenna is about as long as I can have and yet clear my garage door without hitting. This little workhorse works really good for my purpose, ie, receiving and giving info on road hazards, traffic jam avoidance, etc.
