Question
not sure exactly what is an Omnilink system. When the Motorola document says Smartzone and Omnilink, does Omnilink mean a separate linked system that's broadcast as a neighbor with another sys ID or RFSS ID? "Omnilink enabled trunking channels" Is there a way to see if its an omnilink system thru a program such as SDRTrunk?
Another Type II vs P25 bit of confusion. Although most of this info is available online, I'll recap here because I've got a few minutes to kill.
Originally, SmartZone referred to a multi-site Type II system. All sites were under the same SysID in the same "zone", and so subscribers could easily roam from site to site. This of course pre-dates P25 systems, and so RFSS was not a thing, yet.
OmniLink was the multi-zone enhancement to SmartZone systems, where you could link together multiple Type II systems that had differing SysID's to create one giant system. The NJSP SmartZone OmniLink system is an example of this. Originally they were three separate SmartZone systems (B106, B11D, B11E), which were combined to form a single OmniLink system where subscribers could seamlessly roam between sites of differing SysIDs.
Both terms were carried forward to ASTRO 25 systems when setting subscriber coverage. If you set a subscriber to SmartZone coverage, it means that it can roam between sites of the same SysID/RFSS (zone). If you set coverage to SmartZone and OmniLink, it can roam between sites of the same SysID across multiple RFSS (zones) within that system.
If you need to roam between ASTRO 25 sites that are part of different SysID's, you set the coverage to Inter-WACN Roaming. Intra-WACN Roaming is mostly for Harris systems, something I won't get into here because it's not really within the scope of the discussion.
