SNACC reband again?
wa7rat
I'm not hearing radio traffic in Boulder city anymore. Did SNACC reband again? What happen to site 1 in the Database. It was on Red MT. now it's gone?!?
Thanks!
737mech
Clark County, NV.
SNACC
Thanks!
Not sure about that site but I'm getting SNACC no problem including BCPD and FD. Might be time to check your cc's and loaded freqs? I'm hoping someone here submits a full accurate site/freq list to the rrdb for SNACC soon. It seems there are some missing items. For example I have 853.4 showing up on unitrunker as a cc. No mention of it on the rrdb? I'm sure there are many more.
bfperez
What about site 12?
I looked at the FCC info for FRN 0001586155 and found that there's substantial overlap in the frequencies between Red Mountain, Upper Black Mountain and the Rio.
FWIW:
These are largely common with Upper Black Mtn and the Rio, but I didn't see them being used:
WPQF978
0851.1000
0851.3750
0851.4625
0851.6250
0851.9250
0852.1625
0852.2750
0852.9750
0853.5000
0853.8250
WNQU894
Site 12 Red Mtn along with Black, Rio and the 4 sites under WQRK432
0851.0500
0851.2500
0851.4000
0851.5500
0851.6500
0851.9000
0852.2500
0852.4000
0852.6125
0852.9125
0853.1875
0853.4000
0853.8250
0853.9000
0854.3125
0854.4125
0854.7125
0855.7125
0856.2125
0857.1125
Also on the above license:
Shows up on Unitrunker as P25 Site 001-021
0856.7125
0857.7625
0859.2625
0859.9375
P25 Site 001-22
0856.4375
0856.7625
0857.4875
0858.7625
0859.4625
0859.9375 (yep, shows up on both sites)
This leaves these unused on that license.
0856.2625
0860.2625
0860.4875
0860.4875
0860.9375
NORCAL
Saratoga, CA
SNACC Reception Issue
I've been unable to hear Henderson PD on the SNACC for some time. As of Dec 21, I cannot hear Boulder City PD. Has something changed with the SNACC system, frequencies, or settings?
NORCAL
Saratoga, CA
SNACC reception issues
I monitor two (2) sites on the SNACC system based on the RR database. They are listed below:
010 (A) Hacienda Hotel-Boulder City
011 (B) Lake Las Vegas-Henderson
During the week of Christmas, I could not monitor either site. Presently, I'm out of the area and cannot verify that these sites are working right now. Any update on frequencies or system setup is appreciated.
bfperez
I did a license search not too long ago and didn't find a site in that area (Lake LV). Doesn't mean it doesn't exist though.
The frequencies listed are pre-rebanding. For the heck of it, try subtracting 15 from each one and see if you pick up that site.
Do you pick up the control channel for the Hacienda site?
EDIT:
I did a quick look and found an expired license for Lake LV (101 Montelago, Henderson NV)
http://wireless2.fcc.gov/UlsApp/UlsSearch/licenseFreqSum.jsp?licKey=3023441&keyLoc=15538033
ksnwireless
Henderson, Nevada
I am missing some of the HPD and HFD communications. At this time I am only receiving off of location #4 Red Mtn, with all the licensed machines programed. From where I live, I am not receiving the control channel, Lakes Las Vegas. Any suggestions? Kevin
Sent from my SCH-I605 using Tapatalk
bfperez
What do you mean location #4?
Have you had any luck with site 12 as listed in the RRDB?
ksnwireless
Henderson, Nevada
Location #4 is off the FCC website. It states Red Mtn. Site #12 I believe is SNACC's designator for Red Mtn.
ksnwireless
Henderson, Nevada
I'm having fairly good amount of hits. Listen to the Henderson feed on Broadcastify. Let me know? I do not listen full-time.
ksnwireless
Henderson, Nevada
I'm having a fairly good amount of hits. Listen to the Henderson feed on Broadcastify. Let me know? I do not listen full-time.
