software for GRE scanners
Newmarket, NH
#2
PSR500 software
I have been using Butel's ARC-500. This is the only software I have used so I can't compare it to the others you listed. However, I can say that I have been very satisfied with Butel's products over the past several years. I am using ARC-250, ARC396 as well.
You can download a free trial version at www.butel.nl
DaveNF2G
Rensselaer, NY
#3
The only "clear choice" is the one that fits your needs best. The rest is just opinion (and occasionally, if you read the threads here, personal attacks and ranting).
S. Carolina
#4
You can use the trial versions of them to see what fits you. You can also read the posts here and see what, if any, problems people are having. There are yahoo groups for them too and that would be a good place to read about them.
mikey60
Oakland County Michigan
#5
My suggestion as author of PSREdit, is to try all of them (They all have a 30 day trial period) and see which one works best for you. Only you can answer that question.
Mike
