Software for RS 20-163
N9RMA
Is there a downloadable site for my 163 scanner? Need to program sum trunking systems..Also could use a USB cable for said equipment. Thanks Bob N9RMA
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Actually you want this page from our wiki...
PSR-300/400 Software and USB Support - The RadioReference Wiki
With RS pretty much gone, if you can't find the USB cable elsewhere (without paying an arm and a leg for it), it's just possible that the Whistler cable (linked in the USB article referenced above) might work, but since I don't have that scanner, this is mostly a WAG
Mike
jaspence
Michigan
Scanner software
The link I posted gives you the same info. Usually the RS (GRE) cable work for more than one scanner model. I have the Pro 106/Whistler 1040, and the cable for that works with my other RS scanners. OINfo from Scanmaster says the same cable works on that scanner as the Pro 106/Whistler 1040. I have the original version, and it works on Windows 10 64 bit with no problem. The newer version https://whistlergroup.com/collectio...e-cable-for-ws1040-ws1065?variant=27902505286 should work for you.
N9RMA
Good info
Bob 550. Just ordered the cable off the link you gave me. He is a fellow ham. Now on to the software download. Many thanks. 73 de Bob N9RMA
