Some 2019 wildfire freqs - A/A & A/G
zerg901
Arlington MA
from a 2019 document
Rawlins Tanker Base - 123.975 - intended for local use near or at the base
for the following freqs - VHF highband is FM 'air to ground' (onscene - aircraft to firefighters on the ground) - 120 Mhz aviation band is AM for 'air to air' (onscene) - freqs seem to be listed as primary then 2ndary then tertiary - it is possible that all of these freqs will only be used for the first day and night of a major fire - and then be replaced by other freqs on later days of the fire - typically no PL is used
Wyoming Zone 06 - Rock Springs area - 167.225 - 167.50 - 126.675 - 127.575 - 135.875
Central WY area - AA 3 is 134.05
Wyoming Zone 04 - Rawlins to Cheyenne area - 166.9375 - 167.525 - 125.275 - 128.025 - 132.20
Zone 7 - north of Cheyenne in Camp Guernsey area - 167.075 - 167.525 - 119.175 - 126.375 - 134.625
PJH
Global Database Admin
Can you PM me the source information? I'd like to have it organized by the correct area(s) to make it easier for the users
