Sorcerer issue
cj5
California
#1
I'm not sure if anyone else is having this problem, as I've asked elsewhere in the community, and it's been fairly quiet. Anyhow, I am using Sorcerer-setup-1.0.0.exe, and it opens up, showing up in the taskbar, and their is a process running for it, but alas there's not visible window showing. Has anyone else experienced this? Is there a fix for it? I am using Windows 7 btw.
#2
It's just a bug in the software.
Simple fix:
Run-> RegEdt32
Find this key --> HKEY_CURRENT_USER\Software\Sorcerer
Find the (4) values starting with "Main" == MainH, MainW, MainX, MainY
Right-click on each of these and select Delete.
Close RegEdt32
Relaunch Sorcerer.
Fixed.
