Sounds like a busy signal from phone..
govermentcheese
Niles Michigan 49120
Hello I am in Berrien county Michigan. On one of the talkgroups a certain channel when it comes up sounds like a phones busy signal and I noticed on my whistler 1080 screen and E pops up is that what encryption sounds like.. Thanks
mule1075
Washington Pennsylvania
No it is in the settings IIRC. You can set up for a busy signal or another sound etc. Again not 100% sure have not had a whistler scanner in awhile.
You can choose the sound you want the scanner to make when it encounters an encrypted transmission.
BB
tvengr
Well Known Member
Baltimore County, MD
Under the Advanced Features and Audio Options tabs in EZ Scan, you can set encrypted transmissions go give Digital Noise, Silence, or Tone (Busy Signal).
Wackyracer
Yes, that transmission is encrypted and that is the default sounc the scanner usese it can be changed as others have stated.
