South Florida DMR....
Fortified Bunker
#1
Can anyone ID these DMR repeaters...callsign, location, open or closed, etc...
443.175 cc9 slot 2 TG 90275
443.9375 cc9 slot 2 TG 90275
Some of the DMR ID's being used were 3112011, 3112144 and 3112117. I looked them up on DMR-MARC and one is AC4XQ who has the 443.125 DMR machine in North Dade...where I hear mostly slot 1 TG 3 (N America). Repeaterbook also has 443.175 linked to him but analog.
The two above repeaters were linked on that talkgroup and heard in Broward and Southern Palm Beach County.
W4KRR
Coconut Creek, FL
#2
They're the AC4XQ repeaters. The first one is located near the Dade/Broward line. Not sure about the other one. I think they're closed machines, but I'm not positive.
Taxachusetts
#3
Repeaterbook.com is a great Resourse
443.1750
My experience has been Repeaters are on 25 Khz channel spacing not 12.5 Khz, but each region does vary. Nothing on 443.9375 in RB, but could be an image of 443.1750
However, searching by CallSign returns 443.6375
Fortified Bunker
#6
Why would you think there was a "problem?" Was searching the 70cm band and saw these two pop up. Didn't see anything linked to DMR-MARC except your other machine in N Dade. Just wanted to know if they were closed, open, where located, etc. if you care to share.
PALM BEACH, FLORIDA
#7
If you want to get access to these repeaters, you need to contact Rick for the codes. Hey Rick. You've been a member here since 09, & yesterday was your first post?
