Southern NSRS confirmations?
KF7RAY
Reno,NV
Can anyone confirm the following updates so the NSRS DB can be updated? I don't feel like driving down south just for this! ;) I found the updated information, but it needs to be confirmed before the entries can be changed.
9012 (2334) Christmas Tree Pass (Laughlin,NV):
01 851.2875
02 851.8750
03 852.3250
04 855.2375
05 853.5250
06 853.8000
It also appears that 108 (6C) Christmas Tree has expired (ULS License - Public Safety Ntl Plan, 821-824/866-869 MHz, Trunked License - WQIR824 - Nevada, State of - Location 1), the only new information I could find is this:
01 854.9625
02 855.9875
03 856.9625
04 856.7125
05 857.7125
06 858.7125
Using FCC licenses WPRY297 (http://wireless2.fcc.gov/UlsApp/Uls...eNumToReturn=1&keyLoc=14925244&licKey=1950141) and WNZB252 (http://wireless2.fcc.gov/UlsApp/Uls...eNumToReturn=1&keyLoc=14144280&licKey=1302558)
010 (A) Potosi Mountain:
01 856.9375
02 857.9375
03 858.9375
04 853.1125
05 851.2250
06 851.7000
07 852.7500
08 853.1625
09 853.7125
028 (1C) Primm:
01 851.0750
02 851.4250
03 851.8250
04 852.2000
05 852.4250
06 853.1000
07 853.3625
08 853.6250
Vegas_Eric
Las Vegas, NV
I can check Potosi for you right now. But I want to know how to use the FCC Database links you included. I did not see anything about POTOSI in there. Where do I find the Potosi info in your included links.
Programming in your Potosi info into a GRE PSR500 and a UNIDEN BCD396XT right now to check for you.
Eric
01 851.2875
02 851.8750
03 852.3250
04 855.2375
05 853.5250
06 853.8000
01 854.9625
02 855.9875
03 856.9625
04 856.7125
05 857.7125
06 858.7125
Using FCC licenses WPRY297 (ULS License - Public Safety/Spec Emerg, 806-821/851-866 MHz, Trunked License - WPRY297 - NEVADA, STATE OF DEPT. OF TRANS - Location 1) and WNZB252 (ULS License - Public Safety/Spec Emerg, 806-821/851-866 MHz, Trunked License - WNZB252 - State of Nevada - Location 3)
01 856.9375
02 857.9375
03 858.9375
04 853.1125
05 851.2250
06 851.7000
07 852.7500
08 853.1625
09 853.7125
028 (1C) Primm:
01 851.0750
02 851.4250
03 851.8250
04 852.2000
05 852.4250
06 853.1000
07 853.3625
08 853.6250
Vegas_Eric
Las Vegas, NV
I'm Scanning the Potosi Site with both the old & new Frequencies in both Narrow and Standard mode with two different models of scanners. I am only picking up traffic on the new frequencies listed above in EDACS Standard mode!
KF7RAY
Reno,NV
Eric
Thanks Eric, you can see the new Potosi frequencies I found here: ULS License - PubSafty/SpecEmer/PubSaftyNtlPlan,806-817/851-862MHz,Trunked License - WPWL702 - State of Nevada - Location 1
So just to confirm, the frequencies below are the ones that you are hearing traffic on correct?
01 856.9375
02 857.9375
03 858.9375
04 853.1125
05 851.2250
06 851.7000
07 852.7500
08 853.1625
09 853.7125
E5911
the lower desert
nsrs south updates
been beating my head against a wall trying to get this done, without success. I go back to Yuma day after tomorrow so i will program and let you know. I pass oatman, xmas and opal mts
KF7RAY
Reno,NV
Sounds good, I just noticed a few licenses expire and non-rebanded frequencies so I thought I would see what I could find. My only problem is I don't live close enough to confirm them myself. Thanks!
Vegas_Eric
Las Vegas, NV
That is correct. All 9 frequencies in that logical order are what I am listening to NSRS traffic on.
When I click on the link just below where it says "Location 1 - POTOSI"
It says "Frequencies (5)"
Where did you come up with the 9 frequencies and the logical order that I program them in?
Thanks,
Eric
KF7RAY
Reno,NV
Thanks,
Eric
Basically I just noticed that the last five frequencies listed in the NSRS DB were not rebanded yet so I searched the FCC DB just to confirm and noticed that there was two licenses that had Potosi so I just left the first three alone since they were already below 866 and the license for those was still active but there was one new frequency so I added that one and then the new rebanded frequencies after that. I hope that makes sense...:)
KF7RAY
Reno,NV
One more site question, can anybody confirm that 027 (1B) Jean is still active? Looking at the DB, it appears it needs to be rebanded, but I can't find anything new in the FCC DB and the license it shows on RR doesn't have any information for a site named "Jean": WPWL702 (State of Nevada) FCC Callsign Details
Also, I found what appears to be a new or updated site south of Mesquite:
http://wireless2.fcc.gov/UlsApp/Uls...eNumToReturn=1&keyLoc=15618424&licKey=3134825
851.9250
852.3875
852.8875
853.3125
851.0875
851.4750
bfperez
[[SNIP]]
[[SNIP]]
028 (1C) Primm:
[[SNIP]]
Nice! Now I hear traffic on both sites. Thanks for this update.
E5911
the lower desert
Xmas and south
in Needles and the program givin did not seem to work. san beridino worked fine off the same mountain, so I suppose its a LCN issue.
If you guys figure it out let me know
KF7RAY
Reno,NV
Which site are you trying?
Which Christmas tree did you try? The Pass or just "Christmas Tree"?
Try these frequencies:
01 851.3375
02 851.9875
03 852.1250
04 852.6750
05 853.1250
06 853.6000
also, if you were trying the first Laughlin, I messed up the fourth frequency, it should be 853.2375 not 855.2375. See if that helps.
KF7RAY
Reno,NV
Opal...
Can someone also check out Opal and confirm if this LCN is correct?
01 857.7125
02 858.7125
03 859.7125
04 851.3125
05 851.8625
06 853.3250
07 853.9875
