bibbles10504
- Joined
- Nov 20, 2007
- Messages
- 8
Hi,
I have Discone antenna (link) connected to 50' RG8X coax cable (link) which is plugged into my scanner directly with an SO-239 to BNC adaptor (link). The antenna and current setup works great. I would like to set up another scanner and use the same antenna, so I have 2 (or more) scanners using the signal from the same antenna. Is there a way to split the signal from the antenna? If so, what hardware would I need?
I assume I just need a splitter and the right cables / ends? I'm new to the whole antenna thing (usually just use the antenna's that come with the scanner). So any help / specific product links would be greatly appreciated.
