WS1080: Spotsylvania Scanning
#1
I bought a WS1080 a couple years ago when Spotsy moved to the current system but I have had little luck receiving anything from my home near Snell. I can usually pick up the State police here but nothing from Spotsy. If I drive a couple of miles from my house towards Thornburg or Livingston I start to hear Spotsy dispatches. A couple of weekends ago I built an 850 MHz J-pole and shoved it about 20 feet in the air but still nothing from Spotsy although the State Police came in a little better. Could I be in that much of a dead zone here that I can't hear the Thornburg tower that is about 5 miles away? My old analog Radio Shack trunk tracker worked great here before the switch. Or could there be a setting on my scanner that has lowered the sensitivity with regards to Spotsylvania? Any suggestions will be appreciated.
Thanks,
Tom, KK4WPR
fredva
Virginia/West Virginia
#2
Tom, you may be suffering from digital simulcast distortion. Spotsy's system is a simulcast system. Each transmission will go out on the same frequency from multiple towers, and if you are in a bad spot, the signals from two or more towers will arrive at your scanner out of sync and will cause a garbling voice, or no digital decoding will take place at all (silence). If simulcast distortion is the problem, a directional antenna can help by isolating the signal you receive to one tower. There are cell phone directional antennas for the 800 mhz range that are sold on Amazon for around $15, or you could build one.
I have a WS-1080. It works well on listening to the state police, but Spotsylvania's system is spotty.
#3
That might explain why my scanner receives Spotsy if I drive a mile or two from my house in any direction. I am going to whip up a 3 element yagi and give it a try.
Dafe1er
Off in a far away place, far from u.......
#4
Thanks,
Tom, KK4WPR
Also make sure you have updated your Spotsy folder as they had a couple channel changes recently.
#5
I updated them last week but it is easy enough to do it again.
I have a question about the display: what does a blinking white S with a black background (instead of T for trunking) mean? I don't see that S in the manual.
Dafe1er
#6
I believe it is as follows:
S - appears when the squelch circuit is open.
T - blinks when the scanner is receiving a trunking control channel frequency
