# SPY Server Configuration File
# TCP Listener
bind_host = 0.0.0.0
bind_port = 5555-6666
# List Server in Airspy Directory
list_in_directory = 1
# Owner Name
# For example: John Doe L8ZEE
owner_name = Dave
# Owner email
# For example: john@...
owner_email =
# Antenna
# For example: Random Wire/Magnetic Loop/Mini-Whip/Inverted V/etc.
antenna_type =
# Antenna Location
# For example: 48.858332, 2.294560
antenna_location =
# General Description
general_description =
# User sessions
maximum_clients = 1
# Maximum session duration
# In minutes. 0 for no limit
#maximum_session_duration = 0
# Allow clients to retune and change of gain of the device
allow_control = 1
# Device Type
# Possible Values:
# AirspyOne (R0, R2, Mini)
# AirspyHF+
# RTL-SDR
# Auto (Scans for the first available device)
device_type = Auto
# Device Serial Number as 64bit Hex
# For example: 0xDD52D95C904534AD
# A value of 0 will acquire the first available device.
device_serial = 0
# Device Sample Rate
# Possible Values:
# Airspy R0, R2 : 10000000 or 2500000
# Airspy Mini : 6000000 or 3000000
# Airspy HF+ : 768000
# RTL-SDR : 500000 to 3200000
# Comment to use the device's default
device_sample_rate =3000000
# Force 8bit Compression Mode
# The 8bit Compression mode has proven sufficiently good for most streaming use cases.
# Use it to same some internet bandwidth.
force_8bit = 1
# Maximum Bandwidth
# Limits the maximum IQ bandwidth the clients can set
# Recommended value for WFM is 200000
# Recommended value for narrow band modes is 15000
maximum_bandwidth = 200000
# FFT Frames Per Second
fft_fps = 10
# FFT Bins
# Bins = 2^fft_bin_bits
fft_bin_bits = 16
# Initial Center Frequency
#initial_frequency = 7100000
# Minimum Tunable Frequency
# Comment if using the device default
#minimum_frequency = 0
# Maximum Tunable Frequency
#maximum_frequency = 35000000
# Frequency Correction in PPB
#frequency_correction_ppb = 0
# Initial Gain
#initial_gain = 10
# RTL-SDR Sampling mode
# Quadrature = 0,
# Direct Sampling I Branch = 1
# Direct Sampling Q Branch = 2
rtl_sampling_mode = 0
# Converter Offset
# Set to -120000000 to enable the SpyVerter offset
#converter_offset = -120000000
# Bias-Tee
# For AirspyOne only - Useful for LNA's and SpyVerter
#enable_bias_tee = 0
# Buffer Size (in milliseconds)
buffer_size_ms = 50
# Buffer Count
buffer_count = 10
