Sstv ipad
Québec canada
I was wondering if anyone could help to receive sstv on my iPad I put the iPad near the radio speaker or headphones and images do not appear can I connect IPad to my radio for better reception thank you
N2AL
Tennessee
That is a very great question! While I cannot think of an "easy" way to connect it, I would say if you put enough ingenuity into it, you can probably find a way. I'm certain you've heard the phrase, "never say never!"
I believe it would probably take a lot of work, but if Bluetooth or Wifi came into play, it's possible. I know more and more radios are coming out with the ability to pair Bluetooth devices, but at this point it is probably for more audio related purposes. But given enough time I would expect to see someone develop the ability to send and receive data too.
Québec canada
Sstv
Ok heres the deal i own a alinco dx sr8 radio hooked to a homemade dipole i downloaded the black cat SSTV app for my iPad mini i checked on the net were it says to either put the iPhone speaker near the radio speaker for picture réception on 14.230 mhz usb all i receive are pixels and no pictures is it my dipôle my iPad or should i hook up câbles from iPad to radio
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Threads merged. Please don't start multiple threads with the same topic. Thanks.
jwt873
Woodlands, Manitoba
What app are you running on your iPad?
I use the Black Cat Systems "SSTV Slow Scan TV" app -> https://itunes.apple.com/ca/app/sstv-slow-scan-tv/id387910013?mt=8
It works great. I just hold the mic near my radio's speaker and it decodes the data.. I even use it in the car with my mobile. I've decoded SSTV images while I was driving.. (Although they tend to be very noisy due to road noise).
Below is a shot of my iPad Pro 9.7 after it just received an image on 14.230 Mhz. It was propped up on top of my IC-7600's speaker opening.
(Edit.. Just looked back at your second message and see you're using this app.. Where are you listening for SSTV signals? Are you sure they are SSTV signals? You might be hearing something else in which case nothing will decode)
vagrant
ker-muhj-uhn
California
I have used the Black Cat SSTV app on my iPhones and iPads and it works rather well by placing the Apple device near the receiver speaker. From 14.230 on HF to the ISS on 145.800 MHz.
A search on Youtube will provide you with some SSTV signal examples. Just decode one or more of those to ensure things are working. https://www.youtube.com/results?search_query=sstv
If that does not work, my guess is that your microphone is blocked by a case of some kind, or perhaps your microphone is broken. Test it out on the built in recording app. You could of course remove the app and re-install if everything else you try does not work.
